I have seen a lot of posts for outboards not starting and I've taken the information from them and gotten this far. Now I'm stuck so I'll list what I have done so far and what is happening.
Done so far
Replaced condensers
Replaced points
Gapped points to .020
Replaced coils
Replaced Spark plugs and wires.
After replacing these I checked the continuity and all places checked out correctly.
Compression check 80 PSI in each cylinder
Spark tester check - both wires light up the tester
Spark test grounded against block in dark spark looks white to blue.
Gas line checks to the carburetor - gas is making it to the carb
I tried to start the motor several times with no luck.
Sprayed starting fluid into each cylinder just to get it to fire - tried to start -> nothing (this is the real frustrating part considering I have spark)
I have also tried in several throttle positions - Start - just beyond Start - Fast everywhere inbetween. The ground clip on the mag plate seems to be in the correct place for stop.
I have the wire that is coming from the coil next to the cam follower going to the top cylinder.
This engine was given to me so I have no idea of the history. It looks like it was never used or used very little still has plenty of places that have the original paint. Seems to pull easy nothing unusual there. I'm stumped at this point. The fact that I have spark and I spray starting fluid into the cylinders and it doesn't fire at all has me confused. Any help would be appreciated. Thanks!
Done so far
Replaced condensers
Replaced points
Replaced coils
