998cc
Thread starter- Joined
- Mar 30, 2013
- 159
I am in the garage typing with grubby fingers. I pulled the drive to change the U-joints and noticed there is not enough clearance to remove the U-joint closest to the outdrive. The threaded ring is in the way. I assume it meas pulling the shaft out to do the job;is that correct? Is this an easy or difficult job? 3392031 is the drive serial number, and it takes the smooth-end (older style) driveshaft bellows without the rib at each end.
Thanks.
Russ
Thanks.
Russ
