Ike-110722
Thread starter- Joined
- Sep 3, 2007
- 408
Took the boat out today for it's second launch. I have been rebuilding this boat for 8 months. I just replaced all the gaskets and bellows, had a new shift cable put in, so I wanted to check it out. Ran it around slow for about 15 minutes, everything seemed ok. I didn't take it over 1200 rpm, then the engine suddenly started over heating, put the needle on the temp gauge way into the red. Shut it down, took it home on the kicker.
Since I haven't replaced the impeller yet (the boat was sitting unused for years, maybe decades before I got it) I am assuming the impeller needs replacing, and while I'm at it I'll replace the water pump on the engine, and the thermostat.
Any advice would be appreciated.
This is the 6 cylinder in-line (GM 250). The sterndrive is a pre-alpha. Ser no 3216148,
Besides the impeller, what else may I need when I take off the lower unit? Gaskets, lubricants?
The thermostat should be what temp, 140? 160?
Any other suggestions (short of junk it) before I start taking things apart.
Thanks
Thanks
