74sidewinder
- Joined
- Mar 15, 2019
- 21
I believe I found the problem. I was checking at what throttle position the engine starts to bog/ won’t accelerate anymore, it would happen as soon as the throttle plates begin to open which seemed weird to me. I found a post saying “if the mixture screws aren’t set properly the carbs won’t switch to the high speed circuit”. I went back to check my mixture screw setting and they were all around 1 turn and even one at 3/4 of a turn :\ I don’t know how I set them that low could have sworn they were all at 1.5. Anyways I was also reading they usually end up in the 2 - 2.5 turns out range. I set mine to 2 turns out, ran it on muffs and it revs up great in neutral, I took the prop off and ran it in a barrel for a few seconds to see if I could get past 3000 rpms and it was great, got up to 5K, and I quickly brought it down to idle ( didn’t want to damage anything ) I’ve never seen the engine rev this high so I think I’m in the clear. Redid a compression test to make sure nothing was damaged by running lean but everything checks out. Will be heading back to the lake in a week and a half to give the boat hopefully one last test.
Just wanted to to post my findings to help someone else if they were having a similar issue. Glad I found the water intrusion that is fixed now as well. Thanks
