Re: 1972 Mercury 200 20 HP Ignition question
you have a phase maker system with points, thunderbolt ignition. i just worked on my engine with this same ignition system i jst had a bad coil, these are decent ignition systems they can operate over long periods of time without tune up or repair as the manual claims, i feel personally its a strong system, as long as the points are in strong condition, and your stator is functioning fine your in business, these systems dont just "go bad" and i dont know where hes getting the figure 500 dollars from, each part costs its own amount if it goes bad, i e a stator for this motor is about 270 dollars but thats the most expensive part of the ignition system, coils are roughly 70 dollars a piece and a point set each is 100 dollars but you get the arm and everything, so unless all these parts go bad you wont (or shouldnt) be paying over 500 dollars just the price for parts and the shop labor
