1972 Mercury outboard 9.8 bearing carrier housing replacement
ramsey05
Hello all. I’ve recently replaced the carrier bearing housing in my lower unit. I pulled the entire prop shaft out in order to do so. I have everything put back together on the shaft and ready to put it back in lower unit. My shifter will not shift now. I think I inadvertently shifted when prop shaft was out. How to I remedy this? Thanks
Honorary Supreme Mariner
Remove lower unit.------Put shift handle in neutral.----Put lower unit in neutral.----Assemble.
