Re: 1972 Sea Ray Mercruiser 165
I had a similar problem..same motor but had a fresh rebuild. Timing was way off. I'd take the distributor out and start over, dropping her in correctly. I also advanced the timing to 8. Runs a lot smoother and get another couple of rpms.
As for the carb, you need to adjust it after the timing is right. My adjustments were 1 3/4 turns.
