1972 Starcraft Nova
captainnate
I cut a new piece of plywood for the dash, but I couldn't get it wedged in there, so took of the front section of aluminum sheet. Of course to do this I had to take apart the rub rail. I pray I can get the rubber back in the rub rail when the time comes. Also there is a support piece of plywood that sits under the aluminum sheet right at the nose. It's a little rotten, so I'm going to replace it.
captainnate
What should I use to replace the foam squeegee looking stuff they had between the wood support structure and the aluminum sheet? I was thinking maybe a thin plastic cutting board?
MNhunter1
I'll find the pictures from my Nova bow cap reconstruction and get them posted.
I used some foam sill seal from one of the big box stores between the wood and aluminum cap. Just stapled it on with some stainless staples.
captainnate
I took the rest of the dash apart. I wasn't sure about the wires, but it worked out that I didn't have to mess with the wires to the instruments.
captainnate
I was testing the fit before I drill holes in the new dash plywood. I was hoping I could simply reattach the windshield without rebuilding it. I do have one attachment bolt that is broken, and wouldn't mind replacing the other bolts. Do I just drill out the rivets to take the windshield apart? Is it going to be hard to get it back together? Thanks
MNhunter1
Yes, the rivets should drill out like any other rivet. I don't recall it being difficult to put back together, but I only replaced my bottom seal and bolts, so didn't do a full disassembly. I picked up a replacement seal from somewhere, but I'll need to dig through my parts bin to find it and see if I can determine where it came from. Not cheap, but an identical match. The bolts are t-bolts that slide into the channel and pop out through the seal. You'll need to determine the placement and punch those through the seal. If I recall, I couldn't find any stainless replacements, so I ended up using non-stainless t-bolts and just hit them with some paint. Figured they wouldn't see much exposure based on their location anyhow.
MNhunter1
Windshield replacement seal was from Taylor Made Systems, profile 8288020. I purchased 8' at $2.27/ft + shipping and handling...but that was also 2014.
