1972 Starcraft Transom Question
Dan Salvin
I have a 1972 14' Starcraft Holiday (the orange boat). I want to replace the transom and have read many threads here in preparation including one on the same exact boat. One question that I cannot find an answer to is how to get the drain tubes out in order to remove the transom without ruining them. Or, in the alternative, how to find new rain tubes for the new transom if the existing ones have to be destroyed in order to get the old transom out. I have a handle on removing all the other rivets, screws, end caps, etc. but cannot figure out the drain tubes. Thanks for the help! - Dan
jbcurt00
Re: 1972 Starcraft Transom Question
I have a 1972 14' Starcraft Holiday (the orange boat). I want to replace the transom and have read many threads here in preparation including one on the same exact boat. One question that I cannot find an answer to is how to get the drain tubes out in order to remove the transom without ruining them. Or, in the alternative, how to find new drain tubes for the new transom if the existing ones have to be destroyed in order to get the old transom out. I have a handle on removing all the other rivets, screws, end caps, etc. but cannot figure out the drain tubes. Thanks for the help! - Dan
Yep, anyway you can, as long as you don't damage the aluminum transom skin :)
Get new ones right here on iboats...Drain tubes
You'll want 1 of these:
Moeller drain flanging tool, also on iboats
Or build 1 of these:
Welcome to iboats dry dock
