On my 1972 V4 - my carb has 4 screws marked low speed idle adjusting screens located behind the air silencer. I can't find anything mentioned about these 4 adjustment screws in my evinrude service manual.
My motor is idling fine, but I'm curious what the correct setting for these 4 screws are. There is an idle speed adjusting screw next to the throttle arm that the manual cites for setting the correct idle speed RPM. I'm familiar with that one and understand how that operates and I set my idle speed with that screw according to the service manual.
But the 4 screws behind the air silencer puzzle me. My experience with other carbs is these low speed screws would simply control an orifice and thus regulate the fuel mixture at low speed, but this V4 motor has fixed high and low speed jets, no? Or maybe these screws intersect with the low speed jets somehow.
I've acquired two motors of this vintage over the years, and in both cases all 4 low speed adjusting screws were jammed tight (full clockwise until stopped) when I examined them. I also bought a spare carb on ebay recently and sure enough it's 4 low speed adjustment screws were turned all the way CW until tight as well. Shouldn't these be kept open at least 1 turn CCW like typical carbs? My concern is on both carbs (and I have a spare) that anytime these screws are loosened even a 1/4 turn, there doesn't seem to be any resistance at all, so I'm worried that if I don't leave them shut tight, they will just spin around with vibration over time. Maybe there is a grommet that is supposed to be in there that is long ago worn away. Currently, I do have all 4 low speed screws opened about 1 rotation, but I'm worried they will spin freely over time since there is little to no resistance on them. Maybe they will stay put. But on oher carbs, the fuel mixture screws always seem to have a little more resistance so they stay put.
I haven't fully cleaned a carb in a few years, and hek if I took the time to figure out thier function on the bench a few years ago, now my aging brain has forgot already.
