1973 135HP 135ESL73M Timing and idle spec ?'s Still waiting on manual
taylor786
Thanks for your time iboaters! Someone please look this up for me!
Couple weeks ago found this splendid ol motor leaning against a tree. Brought it home and went to work after finding out head gasket blew. Along with improper quality inspection of casting the heads restricting 60% of water flow in the water port due to excess metal during manufacture "fixed now".
That is a long story short.
I ordered a OMC 135ESL73M service manual arriving snail mail not here yet :(
Work done: New Head Gaskets and water gaskets both sides. Rebuilt carbs with new floats. New fuel pump, fuel lines, UL77V Plugs, Water pump rebuild kit. And soaked the pistons with seafoam and TCW3. Pistons and cylinder walls look great!
My questions are
1. Head bolt torque lbs?
2. Water cover/jacket torque lbs?
3. Timing advance specs at idle and recommended idle rpm's?
4. Timing advance at WOT and whats the max rpm's for this motor
5. Please show me where the tip and donation jar is located on this site for your help?
From my family and I we appreciate your knowledge!
taylor786
Re: 1973 135HP 135ESL73M Timing and idle procedures and a couple other spec ?'s
Bump...
