1973 18HP Evenrude,How much is it worth?
herothc2003
I am looking to buy a 1973 18hp evenrude outboard pull start. It's in good shape and I need to find out how much it is worth so I will not pay too much for it. I am in N.C.and it has never been ran in salt water and seem to run pretty good so far but I am going to test it out sat. on my boat to tell. Any info would be greatly appreciated!<br />Thanks, herothc2003
alden135
Re: 1973 18HP Evenrude,How much is it worth?
Check e bay to get an idea. Up this way I see those go between 200 and 800 depending on condition. You should check local Uncle Henry type magazines to help compare local values. I had an 18 evi from the 60's that I wish I never sold. It was a great motor on the 14' glass boat I had at the time. Maybe someone local to you (Yall) on this site will give you a better idea than me though. Good luck.
G DANE
If its running fine, I would pay 300 - 400$ unless its a special gem that spent most of its life in a barn or garage, doing nothing. That being said, they are very fine motors when in good shape. producing silent, smooth power.
Chinewalker
I would agree - somewhere in the $200 - $500 range. Upper end would include gas tank and good fuel line. Also, when was the last time the waterpump was changed? If the seller doesn't know or does know and it was more than two years ago, you can probably push the price down a bit (don't be afraid to ask for a shop receipt). How are the lower unit seals? Bring a big flat-bladed screwdriver and ask to see the lower unit oil AFTER the motor has been run on your test. If the oil looks milky in color, then you can probably wiggle the price down a bit more.<br /><br />If the motor falls into the 'runs, but uncertain service history with possible work needed' category, then you should be able to get it for less than $200. If the motor is presented as ready to go with no work needed, then look to pay at the high end of the range.<br /><br />Another thing to look for - run it under load, on a boat if possible, and note whether it "kachunks" in gear. A repeated noise like that might indicate a worn clutchdog - not an uncommon problem with those motors. It's fixable, but is one more thing to consider...<br /><br />- Scott
