sogafishin
Thread starter- Joined
- Jun 14, 2008
- 21
I put together 1973 25HP Johnson for my fishing boat.Took it out today for the first time and it cranked right up.Run great low end picked the boat up planes out and started surging and shut off hit the starter and it spun over a little bit and fired right up again but wouldnt take off.I held the bulb in my hand and squeezed it as it was running and she runs like a champ.It will run forever under 1/2 throttle without grabbing the bulb but if I gas it to go I have to keep pressure on the bulb to keep it from surging.I know its a fuel problem but is it the fuel pump or the carb?Seems like if it was the fuel pump it would run out of fuel even at slower speeds.Could the float level be too low and me squeezing the bulb push the fuel in it needs?thanks
