Bryan Bunton
Thread starter- Joined
- Jun 8, 2021
- 1
I am having a bit of issue with the motor running. It sound like it is running out of gas when it has a full tank, used fresh gas, checked all fuel lines, rebuilt carburetor, set carb to right setting, and changed plugs. It is using an excessive amount of gas. When I go to rev up the motor, it smokes a lot like it is flooded. What could this be? Also where can I hook up a tachometer to the motor? There is no gray(tach signal) wire.
