1973 50 hp Carb help
94saleen
I am needing to know what years and sizes of motors will interchange with my 1973 50 hp evinrude, I am needing carbs so any help is welcome
Joe Reeves
Re: 1973 50 hp Carb help
Sorry to say that I don't have the carburetors BUT they're easily rebuilt and I'm curious why you would replace them.
94saleen
carbs seem to be flooding and leaking gas, my boat wont go over 10 mph it is a 15' arrowglass tarpin
Joe Reeves
Check compression and spark first, and if all is well in these two area, read on......
You don't need new or used (expensive) carburetors to cure that problem. Make notes, take pictures, etc...... remove, clean, and rebuild those carburetors using new complete carburetor kits. The cause of the flooding you describe is due to either faulty float needle valves or improperly adjusted floats.
With the model number of the engine, you can purchase the kits at this site, NAPA, or your local dealership.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
