1973 ? 50esl73r 50hp johnson
sambrigman
changing the water pump on a johnson, 1973 i think. where to disconnect the shifter? 50hp thanks for help.
oldcatamount
Re: 1973 ? 50esl73r 50hp johnson
guessing here...look underneath the bottom carb for the shift rod/lever connection.
James R
Oldcat' is correct.
Go to boats.net for drawings. Looks like there is the usual threaded pin to be removed below the lower carb.
