1973 65esl-73r Temp gauge ?
yooperangler
I'm recommissioning a 1973 65esl-73r and curious if there's a way to add a temp gauge on this motor ?
pic shows thermostat housing wire on right goes to a temp switch(according to seloc diagram) guessing this is just for overheat ?
Thanks in advance for your input guys:D
JWhit
Re: !973 65esl-73r Temp gauge ?
yes that is just for the overheat alarm. for a temp gauge, if you have a threaded blank near the cylinder head they make a sensor that screws in, then attaches to a gauge. The other option is a sensor that just sits agains the cylinder head and is held down by one of the bolts already there
yooperangler
Thanks for the reply J:)
Aussie Rob
May I ask what you ended up doing in the end with this?
I'm looking at doing the same thing. what guage did you use?
Also are you running a tacho? if so what type
Regards
Rob
Bayswater North, Victoria, Australia
