I have been working on this 6hp for awhile.
I rebuilt the carb,
resealed the lower unit
new evinrude water pump kit
new fuel pump
new lower crankcase O-ring and gasket
2 new plugs
2 new coils
and 2 new breakers/condensers.
even compression at 80psi in both holes.
I test started it today (bucket) the RPMs are fine in idle, but in gear quiet sluggish. about 1/2 the RPM's.
while idling, I pulled the top spark plug wire, and no change to idle.
Replaced top plug wire, and removed bottom plug wire. and engine dies.
I figured it was a spark issue, so i was fiddling with the wires, and noticed a small hole in the plug wire for the top cylinder. and noticed it arking against the engine block. So I know I have a leaking plug wire.
Pulled plugs, bottom is wet looking while top is dry.
Reinstalled plugs, started, and played with the top plug wire some more. no change in performance. Still sluggish in gear.
removed plugs again, top now wet.
So, my questions are. Could the leaking plug wire cause it to not fire the top plug correctly?
Maybe the top cylinder isn't getting gas somehow?
or maybe some other type of fuel delivery problem?
I have never used a outboard this small before, only 115hp. while test starting it in water will it be sluggish in the bucket, but fine on the lake?
(also, my bucket is actually a 50 gallon drum, filled a little more than half way with water)
could prolonged use on only one cylinder cause major engine failure?
I rebuilt the carb,
new fuel pump
2 new plugs
2 new coils
