1973 6hp Seahorse (Im nervous)
nwcove
Re: 1973 6hp Seahorse (Im nervous)
i know what you mean! $$ are tight....or can i assume its euros in your case? jmo, a carb kit is a must do thing when you have the cash, and you dont really need an air compressor to blow things out, on a tight budget you could always pick up a can of air at any computer store....just make sure you use it wisely!! ( pine-sol is a very cheap and effective carb soak too!)
BoatFisho
thanks nwcove, very understanding. no AU$ :). poor health has left me poor in $. bright side is there is always boating and fishing on any budget.
is it possible at all to clean the jets without replacing the gasket?
cajuncook1
Not professional videos, but they can help guide you through ignition diagnostics and repair. The motor in the video is a 1968 Johnson 6hp.
I posted this to help another member, it may help you with the ignition.
Well, after having camera issues and having to use an older video recorder, I finally finished the video. The video was an 1hr and 7 min long, but I had to break up the video into 10 min segment to place on you tube. I had not originally wanted to put on you tube, but photobucket was acting up.
Hopefully will give you a visual and help you some.
Evinrude Gale and Johnson ignition video 1
Evinrude Gale and Johnson ignition video 1 - YouTube
Evinrude Gale and Johnson ignition video 2
Evinrude Gale and Johnson ignition video 2 - YouTube
Evinrude Gale and Johnson ignition video 3
Evinrude Gale and Johnson ignition video 3 - YouTube
Evinrude Gale and Johnson ignition video 4
Evinrude Gale and Johnson ignition video 4 - YouTube
Evinrude Gale and Johnson ignition video 5
Evinrude Gale and Johnson ignition video 5 - YouTube
Evinrude Gale and Johnson ignition video 6
Evinrude Gale and Johnson ignition video 6 - YouTube
Evinrude Gale and Johnson ignition video 7
Evinrude Gale and Johnson ignition video 7 - YouTube
Sorry the camera and video edit software was not all that great. It is very hard to see the spark when I am checking with the spark checker, but in the end I get both set of spark plugs to fire even though you may not be see them. Anyway, I think you will get a good idea how to work on OMC ignition from 1950 to 1973. I know I repeat a lot and videos are a little long, so I had to break each segment into 10 min. I am not that good a videoing or editing.
Hope it helps anyway. Oh, sorry about the caption that the video edit was not activated so it is a little distracting.
Cheers, hope y'all have fun working on old outboards!!!
***[highlight]Oh, by the way, I cleaned the carburetor and connected it to the fuel tank and it started on the 2nd crank!!! It may look old but she will be a runner!!![/highlight]
BoatFisho
thanks for that, always good to get knowledge :)
BoatFisho
will take the OB for its first run on the weekend and report back.
what should i be taking particular attention of when assessing how it runs?
cheers all :)
