1973 85hp evinrude
tashasdaddy
Re: 1973 85hp evinrude
as long as it pees good out the exhaust relief valve. it does not have a tale tail stream.
lindsey
I installed a tell tail as implied on iboats so would u Know what is the safest min water pressure
emdsapmgr
Your engine will probably pump 5-8 lbs pressure at idle and 17-20 when at full speed. Depends on how old the impeller is. You can rent a laser temp gun at any auto parts store. Your engine should idle at 143-150 degrees. It will run lower temps when on plane and the pressure relief valves open-depending on how cold the water is.
ezeke
The thermostat (vernatherm # 0384719) on your engine is 105? F. Normally the engine will run above 100? F. and less than 130? F., measured at the top of the cylinder heads.
autohead18
it should just spray not much but a little bit also you shoul be able to touch palm on # 3-1 should not burn u bad but a little hot if you got major issues your moter would be so hot it would melt wires and burn paint off moter if you have spray you should be good
