turbosetch
Thread starter- Joined
- Apr 16, 2007
- 32
Re: 1973 888 Blew out the engine coupler now!!
Yes your bringing up some good points. I guess patience will be the key here. Alaska summers are short. It sucks not having my boat!!
Well first things first I suppose have to figure out how to lift the engine out now!!
There's always a chance that the shop may find your block has some issue that can't be fixed. At that point, it may be worth considering a short/long block instead for time/money sake. Or you may end up paying to bore the block/turn the crank/etc unnecessarily. once a 302 is .030 over, that's about as far as you can go. Next time, you would likely need a new block. I've heard .040 is doable for a car, but it makes the jacket too thin for the rigors of marine use. You may only need a hone, or it may have already been bored in the past. You just won't know till the shop gets it.
Just some thoughts.
