1973 9-1/2hp Johnson lowboy question
dfrants
just got a 1973 9-1/2hp Johnson lowboy. she idle great with the hood off, but leave it on and it will cough and die out. it will fill will exhaust and choke out. is there a bad gasket or seal that would cause this?
F_R
Honorary Supreme Mariner
There are a number of causes for that.
1. Running in a barrel. Forget it, they won't run in a barrel with the hood on.
2. The rubber seal between the inner and outer housings. If bad, it will smother at dockside, but be ok under way at speed
3. Missing seal on top of the water pump housing. Or missing spacer if long shaft.
4. Torn rubber bellows boot on the upper shift rod.
All of the above will introduce smoke under the hood and smother it out.
