christo555
Thread starter- Joined
- Aug 12, 2010
- 49
after replacing the rear propshaft bearing race carrier in my lower unit, i found that the propshaft went in and out about .062".
the tapered roller bearings at each end of the shaft which sit in the respective races determine the propshaft location in the case and therefore the engagement of the forward and reverse gears on the propshaft with the pinion gear,and the engagement with the rear propshaft oil seal.
in my glenn's manual, it says very important to have .000+/-.001" endplay on the propshaft while my seloc seems to say that .010+/-.001" is required.
web search on tapered roller bearings in general seems to say .000" with preloading of amount i can't understand as it talks about force necessary to rotate the shaft.
the end play is adjusted by the thickness of the shims between the bearing race and the bearing carrier, so you have to make a endplay measurement with a dial micrometer, remove the carrier from the case, remove the race from the carrier, place the proper thicknesses of shims in the carrier, and then bang the race back into the carrier against the shims.
is all this necessary? should i just ignore the .062" end play because the rear propshaft oil seal can handle the propshaft side to side movement and the tapered bearings can handle slop in engagement between them and the race???
thanks for any thoughts on this,
christo555
christo555
