christo555
Thread starter- Joined
- Aug 12, 2010
- 49
steering wheel won't turn. disconnected motor universal bolt from steering cable and motor turns freely. unscrewed big nut on cable at steering wheel rack and pinion and rack moved freely. so, i guess the steering cable is frozen inside its sheath. to replace the cable, i have to get the the spring held universal bolt holder off the end of the cable rod so i can pull it through the transom mounted steering tube. but i don't know how to remove it. it is too big to go through the steering tube. what am i not seeing? the frozen cable says "13" on it. means 13 feet long cable needed. the rack part looks like a 1 1/2 inch pipe with a pipe end cap on one end and the steering cable comes out the other end.any help would be greatly appreciated.
