1973 evinrude 115 idle fast and missfire
GREE
Hey guys thank you for taking time out to read and respond. I have a 1973 evinrude 115 that I'm trying to get running better. It has a high idle and it missfires every other second my motor isn't straight up and down it is tilted. could that cause the missfires? What'ssome things I could do? Thank you once again.
211libwtfo
No expert here but motor straightness eh....
id start with timing, carb and spark. How’s the compression?
Honorary Supreme Mariner
Carburetors opening too soon will cause a misfire.------Have you confirmed spark on all 4 that jumps a gap of 7/16" or more , yes or no ?----And post your compression numbers too.----Did this problem start suddenly ?----A " new to you motor " perhaps.
oldboat1
Exhaust popping and high idle are typical when running on muffs. Try it in the water.
GREE
The compression I tested last fall I had from 110-115 on all 4 cylinders. I can confirm spark as of last fall on all 4 I will check to make sure it is all sparking this weekend and I'll have to check the gap. I got champion spark plugs QL77JC4. I will try to make the motor straight is there a way I could make a video and post it?
