1973 evinrude 115 overcharging problem
edgarop
hey i have a 115 that is charging at 17 volts from mid to high rpms and at idle it charges at 14 volts. whats wrong with the motor? thanks
petryshyn
Re: 1973 evinrude 115 overcharging problem
Nothing wrong. Thats the nature of a charging system without a regulator. Yours only has a rectifier. Be sure to keep topping the battery up with water, as it will lose its level over time...
seahorse5
A system like that one depends on the battery as a voltage regulator. The higher capacity the battery, the steadier the voltage stays.
You cannot use a maintenance free or a sealed battery with your unregulated charging system. A group 27 or 31 battery that you can add water to works the best. Another fix is to wire 2 batteries in parallel.
Back in those days, we also turned on the running lights to help dissipate the excess voltage.
edgarop
is there a way to adapt a voltage regulator? my VHF radio doesnt like the high voltage.
boobie
You can also go to any BRP dlr and get a part # 173640 regualtor kit. They came out about the time this mtr was built.
