clemsonfor
Thread starter- Joined
- Sep 19, 2005
- 1,011
Ok so I rebuilt this lower with the parts that were bad. All new seals etc. Ran it, next day or two noticed gear oil leaking. So pull it off and pressure test it. Leaking under water pump housing. So I pull it off and pull the plate up to see. Well the drive shaft seal is not leaking but it's coming from the front of the motor that void in front of the drive shaft that has the little drain hole in it...see pic. My only thought is that there is a crack in there? I'm trying to clean the crud up in there to see if I can see anything. Any thoughts on the source?
Where I am pointing with the screw driver is where the bubbles come from down toward the bottom best I can tell.
