brsoo
Thread starter- Joined
- Jul 23, 2015
- 65
Just wanted to post my results. This motor has been pretty hard to figure out and I'm possibly still working on it.
I started it almost immediately the very first time I hooked a tank to it. But it would only run at wot with no choke. If I tried to bring it down it would cough and misfire? Then die out. I happened to also have a johnson 71 25hp so I figured they where almost the same motor. I rebuilt my one carb with parts from both to use the best parts.
Then I rebuilt the fuel pump
It still didn't run.
I then re gapped the points and plugs.
Still didn't run.
After a LOT of research I decided maybe I was mixing the wrong parts. And maybe I had a weak spark? (Initial problem)
I found one person suggest the spark being stronger removed from the cylinder. So I put old plugs in the block with new ones grounded. It did show a weak spark!
So this was my fix...
New condensers
Cleaned and set points.
Flywheel was not tight enough.
Spark plug wires where loose.
They where not pushed into coil far enough
New plug wires. Stripped like speaker wire to create stronger contact!
Tested jumped 1/4 inch.
Carb rebuild kit.
Later found fuel pumps where not interchangeable.
In short.
Do not mix parts until you rule out the issue.
Check for weak spark with a tester.
Don't try to rebuild a fuel pump of these years
Buy a carb kit.
I think I had weak spark and that's why it ran funny.
Then after fixing the spark I found I changed too many parts. Turned out the fuel pump I changed out wasn't the same and changed the ratio.
I hope this helps someone in the future and sorry for rambling. Just trying to help others!
I was pulling my hair out on this...
If you have anything similar feel free to ask!
I now know my motor pretty well!
Still didn't run.
New condensers
Carb rebuild kit.
In short.
Buy a carb kit.
