busted-bayliner
- Joined
- Jun 6, 2010
- 228
Re: 1973 evinrude 65hp slow on water ???
thanks for your reply i plan to hit the water in the am i will post resultsBecause of your Timer Base not traveling all the way to the stopping point on the block explains your whole problemYes, that wire harness on the right is the Timer base Trigger/Sensor wires, Stator and Charge Coils on the left, two wire harnesses with 4 wires each 8 wires total, 4 wires for the three triggers and the other 4 wires are for the Stator and the three Charge coils. You should be good to go once you give that timer base wire harness a little slack
