Recently purchased a 1973 Fiberform and have been working on it. My first boat so not very experienced, but figuring things out. Has a Mercruiser Pre Alpha Outdrive, 1973 Chevy Inline straight 6. Was taking on water so pulled it out and found out the bellows were shot. Took apart the outdrive, working on replacing the bellows and the shift cable, when I noticed the shift cable doesn't screw in the right way. Upon looking into it, found out they discontinued the older style cable and I have to tap out the hole so I can screw it in from the other side.
Now I am waiting on the pipe tap, and figured since it's already out of the water why not completely redo the boat. Gutted the hull, replacing the board over the gas tank, redoing all the seats(might have to outright buy a new captains lounge chair, saw some on ********, but maybe someone knows of a cheaper one?) Also the flooring, I found some vinyl flooring at http://www.perfectfit.com/15627/1540...ooring-72.html . Need to go with 4 yards of the material, and I am going to be getting the dark blue. What I need help with is what prep work should I do to the floor before laying down the vinyl? Also wanting to repaint the outdrive, but has grease working on the bellows and cant seem to really get it off... Any ideas on what I could use that would make it nice and clean before I repaint it? Thanks for any help/advice!
Here are some pics of before I removed the outdrive, and outside of boat...
