1973 Johnson 25 acting like prop hub spun...
Howard Sterndrive
but it hasn't spun. I tried several props. It does it the worst with the 12P. almost held on plane with a 10P, but then slipped.
If the dogs in the lower were gone, I would expect clunking. But this feels exactly like a spun prop hub.
Holds torque until just about to plane then revs up.
Could there be a spline somewhere slipping?
not familiar with how these lowers connect to the powerhead... but I suspect I'll be finding out here soon.
besides the prop I don't see where it could slip... no signs of anything going on with the shear pin...looks fine
not a ventilation issue or anything like that- I have my identical 1975 25HP on the boat now. I put the same props on it - no problem on the '75
restornator
Re: 1973 Johnson 25 acting like prop hub spun...
you said you wouldn't notice a slipping clutch dog. it can act just like a spun hub, and without any resistance from the propeller, it will rev up. best to turn the clutch dog around (if reverse is okay) adn try again. If it acts the same, you are looking at forward gear (or pinion gear, drive shaft, or crankshaft)
lindy46
Did you actually confirm that the hubs are not spinning by drawing a line across the prop/hub? Maybe you have two spun props.
Howard Sterndrive
I noticed afterward, that one of the props was indeed scribed. the marks were aligned
plus they don't slip on my other 25
can't see why a prop would slip on one identical motor and not the other
Andy in NY
is your motor too high or trimmed out too much? could be ventilating.
jtexas
yup. or cavitating. any kind of damage or irregularity on the lower unit, if it blocks the flow of water into the blades, will cause cavitation.
or if a piece of the antiventilation plate is broke off.
Howard Sterndrive
I'll pull the lower off this weekend
must be the vertical shaft into the powerhead
