1973 johnson 25hp 25R73A
Roadking57
Okay! New Tankless water heater all installed!! Now I am cleared back to boat engine stuff!!!
Roadking57
Okay! I disassembled the 73. Found it to be a rusted piece of @#$%. Crankshaft rusted bad, journals pitted. Piston rods and bearing pins rusted bad, pistons look only slightly better than the ones I took out of the 70. Soooo so much for that engine, maybe later. So now I order new pistons and continue with the 70. Its innerds look almost new compared to the 73. (both 25hp johnsons).
Anyone know for sure which way the top ring chamfer is supposed to go? the 73 rings were not stuck (like the 70 was). The beveled edge was installed facing top of piston.
Roadking57
Ahh okay I see that now that I cleaned up those old pistons.
I was cleaning up gasket surfaces and noticed 3 of 4 rubber mounts that hold the lower motor cover on were broken. I tried to remove the nut from last one to facilitate cleaning and painting and it broke off with hardly any torque. Ok I figured no problem let me order some new ones if they are available...
$39 each? Wow! No way. Not spending $160 plus on rubber mounts! Is that normal? Seems kinda high to me.
Anyway I found some online I think will work just fine. 4 set for $16 on good Ol, Be here tomorrow, Amazon.
Roadking57
Question
After searching this forum I havent found much on what brand of portable fuel tanks are better or to stay away from. I think I've read Attwood's are junk somewhere. Anyway I'm in need of a new tank soon. What would y'all buy? I need fuel line and all.
Roadking57
okay further disassembly causes me to need a motor cover to exhaust gasket
0308292​
Im running into NLA.
My old one is in one piece but squashed pretty bad, and its very soft,& semi thick.
Any suggestions?
Roadking57
Question
Whats this hole supposed to be? Grease fitting?
before and after removing corrosion on engine pan
Roadking57
Maybe I should get this post moved to Boat Restoration building and repair? Just a thought.
tphoyt
I would say that hole was either a grease fitting or a tensioning screw for the steering.
Roadking57
Had to come back in here to say,
My New Pistons are Here!!!!!!!!! The rings came installed. I did notice they have small tapered ends. Do I need to measure the gap like car engine rings and file them if needed? I noticed the pistons have small pins to hold the rings from turning inside the grooves at the wrist pin on opposite sides.
Roadking57
Okay!! returned home from work and its christmas again...sort of. Another box of boat motor parts!!!!! The Thermostat and carburetor kit has arrived.
I have searched all over the internet for the motor cover to exhaust seal. Im afraid its NLA :-( Gonna have to find some semi soft material and make it myself. Anyone else make one? If so what did you use?
tphoyt
I made one from gasket material I got at Napa auto parts. I don’t have a part number but I can say it’s blue and 3/64 in thickness.
Roadking57
Well, after cleaning the black off the old gasket a bit I discovered its made out of thick cork. Thank you for the tip tphoyt! I do have a napa near me I will stop by there otw home and inquire if they have anything like that. Otherwise its back to the good 'Ol internet. See if I can order 3/64th or thicker roll of cork. Maybe make several and sell em?
Roadking57
Removed the upper and lower plug screws and about an ounce of gear oil drained out. Looks dark brown but no water present. Still going to open her up, inspect, and reseal.
Do a full inspection before spending beer tokens.----Don't overlook the o-ring on the shift rod if you reseal the gearcase.
