1973 Johnson 65hp will not turn over...help please
adcampbe
I have a 1973 Johnson 65hp outboard. A few weeks ago I tried to start it for the first time in about 18 months. The engine won't turn over. I have removed the plugs and have been applying penetrating oil in the cylinders. I put a breaker bar on the nut over the flywheel thinking I should be able to break it loose, but no luck. Any ideas on what to try next. All ideas appreciated.
Honorary Supreme Mariner
Just picked up a 1988 model 60 HP like yours.---Was stuck from sitting outside for 3 years uncovered.------Got it turning with a prybar.------Then took it apart to find every bearing rusted and scrap.----Crankshaft is scrap.----The 3 rods are scrap.----Water pump totally destroyed from running dry.----Traded stuff that I paid very little for to get this motor.
