bowtieboy77
Thread starter- Joined
- Apr 12, 2008
- 11
I took my motor in to a marine shop last year for a tune up and to diagnose why it would rev in nuetral but not rev up in gear. The problem was a bad plug wire. I will not take it back there as I caught him lying about repairs billed but not performed. I took it north Moose hunting and it starts and runs great the problem is if you are travelling down or up river at full throttle at times it feels like its only 3/4 throttle and suddenly it will just take off and it runs the way it should. If you let off throttle to go through a shallow section and then return to full throttle it might rev up to max throttle/rpm or it might again be lacking in top end power for awhile until it suddenly revs up again if it does at all. I took the cover off in a open section of the river and traveled at full throttle I checked for the choke linkage sticking but choke was wide open. I also watched the trottle linkage and gear mechanism and its not binding up and its going to full throttle no problem found. Could this be more electrical then mechanical? Any help is greatly appreciated.
