1973 Johnson 9.9 stopped working
Mike from Gloucester
I have a 73 Johnson 9.9 long shaft new to me this year. It was working the other day and all of a sudden stopped. There were remnants of a plastic plastic bag wrapped around the propeller. I unwrapped but still not working. Any thoughts? it seems like no one wants to work on something that old.
Thanks for any info or advice
jeff_smith_0423
Re: 1973 Johnson 9.9 stopped working
Did the motor overheat or was the plastic just wrapped around the prop shaft?
14ftgrumman
Does the motor turn over freeely? Pull the plugs and pull the starter rope. While you have the plugs out, check the compression and spark.
If it's got gas, spark and compression, it has to run.
Start ffirst by reading the "top secret" files. Ths will get you headed in the right direction and give you a troubleshooting flow chart.
