The boat man 12
- Joined
- Jul 29, 2021
- 3
Had the engine running great last week. New impeller installed at the start of the season no more than 3 hrs on it. I thermally tested all the heads after the impeller installed and they all were all running at approximately 140 f. Then after I fixed a seal issue in the lower unit the other day and reinstalled LU, I find cylinder 1 is overheating badly at idol.( I don’t know at higher rpm too scared to take it out.) The temperature would rise steadily and I shut it down when it hit 200 f. There is definitely water going up and hot water coming down. Also, I flushed a small amount of hose water (with the LU off) up through the through coolant tubes and I could feel all the heads getting cold including the one that was overheating . Any ideas? Thanks.
