ShowMeGuy
- Joined
- Jan 31, 2012
- 560
What is the max timing advance on my 1973 Merc 850? SN 3740426 Is it max 21 or 34 deg?
I'm going to do this this evening.
http://forums.iboats.com/showthread.php?t=168855
But had a questions on the Max timing advance portion comment below.
Timing Event Two - max advance.
As you continue to advance the throttle the timing will advance while the carbs slowly open a bit more. The next adjustment is max advance, this is the point where the distibutor (or trigger) can advance no more. Set the max-advance stop to 21 degrees for "direct charge" crossflow inlines and 34 degrees for the older plain vanilla crossflows. Use the light, - err to the side of caution.
TIA!
TIA!
