jlconrad24
Thread starter- Joined
- Jul 8, 2011
- 4
I got this 1973 Beau Jack T169 a few months back. Started and ran great on the muffs. In the water in starts every time and runs great just scooting around, but if I go to plane off toward full throttle it dies, unless I can get it back into neutral in time. It has a new tank, bulb, lines, spark plugs, and just put a pump kit in it. Seems to sustain higher rpm longer now, but still results in a dead motor that will start back as soon as I hit the key??? The thing that has me stumped to pulling my hair out is the stinking lower unit. When I first put it in the water the reverse lock did not work. Someone gave me the tip that the cam was out of line from a recently installed water pump. Dropped the lower unit for the first time ever. Couldn't get it lined up, so I had the bright idea to put the shifter in reverse, line up the cam, and go back together so it would be lined up. On the trailer it worked like a top. Reverse shift locked, front shift unlocked. Got it to the water and front throttle was reverse and reverse throttle was forward with it locked down in reverse throttle but being forward gear and vise versa. Took it apart again and it just had forward no matter what I did with the shifter. Took it apart again and now I believe it just has reverse no matter what I do to the shifter. It is driving me nuts to the point I just got home from work at 11 pm and tried it again with no avail.
