Zenvalo
Thread starter- Joined
- Jun 1, 2009
- 74
Hi all!
Just got my first Merc motor ever, it's a 1973 500EL Thunderbolt 50hp. I have it on the back of a 14' Glassmaster Bassmate IV. Dry weight of the boat is approx. 650 lbs.
Took it out for the first time today, total of 2 adults and 1 kid, approx total people weight 550 lbs. It would not plane out, seemed extremely underpowered and burned through about 3 gallons of fuel in 30 minutes. It also didn't like to stay running every so often at low idle. Compression tested out at 125psi across all 4 cylinders. Lower unit was just rebuilt and new impeller was installed, so it's something up top aside from compression.
After pulling the boat out and tilting the motor most of the way up, I noticed gas dripping out of the motor housing also. I think a carb rebuild is in order, but is there anything else I should look in to? Like I said, this is my first Merc, so I hope it's something easy to rectify.
Thank you for any and all suggestions and if there is anything I may have failed to mention as far as descriptions, let me know!
*Edit* I put brand new plugs in before taking it out and I visually inspected them when I got home. It appears all 4 are firing. The top three had a normal amount of burnt fuel/oil mix on them, but the bottom one was only slightly "burnt". Also, see my post below about the fuel lines(?) that I noticed when I looked a little closer on the port side.
Thanks again!
~Zen
Thanks again!
~Zen
