sphelps
- Joined
- Nov 16, 2011
- 11,508
Lets back up a second ... Are you sure the transom is rotted ... Did you drill any core sample holes and inspect the shavings ? You said it was wet .. What part was wet ? If the wood in the top part of the transom is not rotted you may be able to leave that section ... Even still you could actually cut up the edge and pack the seacast in on the 2 upper wings . Its pretty thick stuff ... The catch is you will need to pour the bottom part then let that part set up then pack the wings full ... Otherwise it will keep running out and get quite messy ... How good are you with a chainsaw and do you have one ?
