WhidbeyBob
- Joined
- May 18, 2010
- 21
Hey Guys,
First post...been lurking here since my wife found a 1973 21' Starcraft Cuddy on clist about a week ago. I'm not sure which model but it has a 165 HP Mercrusier I/O. He?s asking $3000 for her. Here is the link to the add http://seattle.craigslist.org/skc/boa/1742489594.html
Using the questions from Jasoutside's thread about boats on clist here are the answers I got when I called up the current owner.
What year is the boat? 1973 (I added this question)
Does it have the original paint? No. He painted it about 5 years ago. I?m not thrilled about the color. Maybe it looks better in person.
Does it leak at all? How much? Yes, it leaks a little. Bilge pumps keep up with the seepage. He had it out on the water for a week recently and never had a problem with water.
What condition is the floor? Is it original? Any soft spots? He rebuild it about 5 years ago using marine grade plywood.
How about the transom ? is it solid or soft? It was replaced about 5 years ago using marine grade plywood.
What?s the winterizing process been on the motor since you?ve owned it? Motor has not been winterized he runs it all year round but does routine maintenance.
How often have you changed the drive oil? Didn?t ask?I was getting excited and skipped over it.
How long has it been since you?ve changed the impeller? Didn?t ask?I was getting excited and skipped over it. (Even with the question right in front of me I couldn?t focus enough to ask?not a good sign. I think whatever you guys have is contagious across the internets.)
What?s the temp of the engine after it?s warmed up? Runs good never had a problem with motor.
What?s the compression on all cylinders? Didn?t have any need to check. It runs good.
So, I?m headed over to check it out but before I do...what do you all think?
Thanks for the input.
-Bob
-Bob
