crankbait cowboy
- Joined
- Mar 25, 2013
- 620
Re: 1973 starcraft ss restore in progress
so i did some tinkering today in 20 below farenhiet weather. fired up 3 sunflower heaters in garage and tried a compression test. first i took out all 4 plugs and set carbs full open with a pliers (pic1) then i pulled fuse to the remote start (pic 2 ) and jumped battery cable direct to starter to crank over (pic 3 ) next was fog oil in cyinders and in both carbs while cranking (pic 4 ) then i did my compression tests and 3 holes came up 95 and 1 hole 85. pretty even numbers , but seems to be on low side.my plugs looked good and no metal shaving on or about them. i did not get real good cranking power ( due to cold,or poor cables or dragging starter? ) and am wondering if this would affect my numbers. do you think i would get better numbers with better cranking ( makes sense to me ) and should compression be done a different way? ( i.e warm engine , regular fuel flow...ect ) my thinking is to be sure i got good compression before moving on to other items ( spark,wires,fuel pump, decarb, water pump,lower unit ect..) if compression is poor i dont want to spend the time or money to get it running. ( it does not run as of today, but have not tried either ) pics in next post, and thanks for any insight any of you may have.
