1973 starcraft ss restore in progress
SigSaurP229
Re: 1973 starcraft ss restore in progress
ooopppssss somehow double posted man I need to go to bed.
dozerII
I agree with Sig a real good decarb with Seafoam then do your compression test, that stuff works wonders.
crankbait cowboy
thanks guys, i like the way ya think. it is well lubed with the fogging oil, but after hearing from you all and sleeping on it, i agree that i will try get her fired up, decarb with seafoam and get er warm and then try another test. not giving up yet!
crankbait cowboy
been really busy at work , so not much progress. did get a couple of hours last night , so experimented with stripping bottom paint. spent 10 minutes brushing on the klean strip adhesive remover, and let sit for about 1/2 hour while getting power washer set up. it was 50 degrees and only sat 1/2 hour with no plastic covering. came off real nicely and my thoughts are with warmer weather and plastic it will work even better. this bottom blue paint is some bad stuff, and sanding was getting me nowhere. so am pretty happy with how the stripping is working. hoping to sand the sides as they are in much better shape paint wise. i rinsed what is done with h20 for now , wondering if that is sufficient for now as going to be awhile before i am ready to paint, and will do a good vinagr wash before that. thanks for stopping by and let me know if i am missing or doing somethin wrong. would post some pics, but it tells me my file exceeds the limit of 20000. any help in how i change my photo size or what needs to be done?
dozerII
Hey CC, I thinkyour going to have to try Photobucket, as nothing is showing up.
crankbait cowboy
IMG_0241_zpsae9ec10e.jpg~c200
IMG_0240_zps976a00e4.jpg~c200
IMG_0239_zpsf9717261.jpg~c200
how bout now. thanks doz
Watermann
What the heck, only 1 measly coat of paint? :lol: Glad you're not fighting too hard to get down to some clean AL.
I really hate stripping paint...
crankbait cowboy
so i got some areas not coming off and was thinking about cleaning them up with some sanding. question for the mob is should i clean up with vinagar /h20 scuff it a bit, clean again before the self etch bomb? thanks
jbcurt00
No reason to use vinegar & water 50/50 BEFORE you scuff it. Clean it before scuffing, sure, but acid wash is after scuffing
GA_Boater
The 57 Variety people make a stronger vinegar for cleaning.
anderso8623
I used klean strip and a power washer. I ended up not using the power washer and used a plastic scraper insted. Worked 10* better! Power washed after and it turned out great!
crankbait cowboy
been really busy at work at not much tin time , but did manage to get er stripped for the most part. gotta do some touch up with a sander and got some of that filmy blue smeg to remove on the bottom. then on to a good wash with hot soapy water. then an acid wash with 50/50 vinager and water followed by a good hot water nuetralizer wash and let dry before spray bombing the self etch rusto. any of you feel i should scuff it all with 220 sand paper before an acid wash to help the self etch adhere or not a neccessary step? thanks for stoppin by, and any advice on my plan moving forward is always appreciated.
IMG_0244_zpsbad9356b.jpg~c200
IMG_0245_zpsd10315fd.jpg~c200
