Watermann
- Joined
- Jan 12, 2013
- 13,827
Re: 1973 starcraft ss restore in progress
What I did was get a piece of 1/16" aluminum, cut it to length with it being wide enough to be extended over each side about 3/8". I screwed the flat piece in place to the top of the wood and started heating the outer edge where the transom skin is so there's a sharp edge to bend the lip over as it was heated. Once the outside was bent over and cooled, remove and switch it around putting the hang over part of the new cap outside again. Then repeat the heating and hammering. I did this before any painting of the hull or finish on the transom wood.
Here is how it looks, not too bad really can't tell it isn't factory/
