170freedom
Thread starter- Joined
- Nov 3, 2009
- 135
I have a '73 starcraft chieftan. mercruiser 165 in/out. I have fully adjusted the forward/reverse cable as to the oem mercruiser manual. HOWEVER- I can disconnect the cable at the gimbal houseing, and while the engine is idling hooked up to muffs, I can by hand move the cable to engage forward with no problem. I then do the same for reverse, when I pull the cable all the way until it stops, the outdrive is not fully engaged. The cable is new, and the outdrive is a fresh rebuild. It would appear to me, that somehow I am unable to get full motion out of the linkage??? Any help is appreciated- thx in advance-
