1973 Supersport SS16 Rebuild
budski
No Title
Thanks JB, got the front side panels and speakers installed.
budski
No Title
We fabricated some SS bow rails
ezmobee
Those rails look real nice. I scored some similar low profile stainless rails off ebay for my SS and love them.
budski
Thanks guys, I find then great for docking the boat, gives you something to grab to hold the boat in place, have had them on most of my other boats.
budski
No Title
attach10342106.jpg photo258883.jpg We trailer built a swing hitch for the trailer, gives us two feet working room in the hanger.
budski
No Title
Got the swing hitch and coupler painted and installed.
Watermann
I sure like the swing tongue on my SS trailer, that looks nice and sturdy.
Alumarine
That tongue looks great!
Do you use a torch and grinder or do you have a plasma cutter?
budski
Thanks Rob, they are a great space saver, we put the on most of out trailers,Thanks Marc this last one I cut out parts with a cutoff blade on an angle grinder, and my son welded it together with a mig welder, got the pin and bolt at Princess auto.
budski
No Title
Got one sanded getting ready for paint.
Scottboat
Hi Budski. I have been following your threads a bit. I found the one when you re did the Sea Nymph SS175 from about 11/2 ago. I have that same boat. I need to replace my floor as you did. the existing floor is 1/2 ply (marine grade). Did you, and should i , replace with the same thickness ply ? I am assuming I should, but this is my first foray in to boat rebuilding. thks for any info you can pass along.
budski
Hey Scott,I replaced the floor with 5/8 plywood, and sealed it with spar varnish, then vinyl flooring.
Scottboat
Great. I am inclined to upgrade to a thicker ply. my main concern was if the added weight , from the slightly thicker ply, albeit minimal , would be enough to affect the floatation, planing etc.
jbcurt00
Scottboat start a topic about your SeaNymph. Ask your questions there. That way the details and help about your boat rebuild will be in a topic about your boat.
budski
No Title
Got the rub rail and end caps back on.
Tnstratofam
Looks good. :encouragement:
Is this pile of wirring for the boat?
If so I think there might be some late nights in your alls future.:faint2:
