chrishayes
Thread starter- Joined
- Apr 9, 2009
- 691
Re: 1973 wellcraft 165 sport airslot project w/ pics
So as I was saying, I had to drill a few holes in my transom...
These are for the motor mount, T&T, tie down hooks and drainholes for both the bilge and splashwell. I drilled them with these new shiny tools!
Redfury posted about using forstner bits so I picked up a decent set from 1/4" up to 2 1/2". I used a bit that was 1/4" larger diameter on all these holes so that I can refill the hole with epoxy PB, allow that to cure, then redrill the correct size hole. I want to make sure that if water seeps through the bolts that they wont have any wood to rot. Again, this is just the overkill that this project has taken on. Water is the enemy and I will continue to base every build decision on that fact and do whatever it takes to avoid allowing the enemy to destroy my boat again!
Here is a cool picture showing the thickness of the transom.
THis is from the rear of the transom in
And this is from the inside out. It shows the thickness of 2 layers of 1708.
And here are a few more pics of the carnage
