Watermann
- Joined
- Jan 12, 2013
- 13,824
Looks like carbon from the exhaust with a dose of pre-mix, there's a drain hose from the air box to the powerhead so when you tilt it up the fuel that spills out of the carb throats into the airbox and when tilted down it goes from the the motor down the exhaust leg. It's very common on these old motors.
Probably could use a good seafoam hot soak too and run on the lake for several miles.
