1974 18' HOLIDAY
Kitch
This is going to be a center console,so the dash and ALL had to go.almost all the rivets in floor supports were broken.
I think if I use aluminum cleaner it will remove the protective coating that forms on alum over time.I spent 2 hrs pulling screws with drill
before I got SMART and broke out the stilh it took 4 minutes to knock it out. GUTTED.jpg
GA_Boater
Hi, Kitch.
This one is interesting. So far she's gone from a closed bow Holiday to a open bow rider and now to a center console.
We have to keep an eye on you. LOL
Kitch
Yeppers, it was converted to a open bow by the PO and all the wood{2 layers of floor and all kinds of storage units in
the bow area were all 3/4" plywood and waterlogged! I bet it was 4-500 lbs. of rotten wood.nice to start FRESH.
Kitch
My biggest concern is how to seal these old holes 100% before I put my new motor on.its a completely different bolt pattern.
Hey GA_BOATER IM IN BUFORD, looks like were in the same neck of the waves! old holes.jpg
GA_Boater
Canton here. Almost next door neighbors.
Can you get some pics of the inside of the stern? Could help come up with a plan for the holes.
If you want, I can move this to the Starcraft section where more Starcraft guys see the thread. We have hundred of rebuilds and many have gone through the same issues with holes needing patched.
Kitch
SURE MOVE IT OVER, I think that's a great idea.
GA_Boater
Moved and I won't tell the landlord you tiptoed out in the middle of the night. :D
So Welcome to the Starmada, the home of all things Starcraft.
Kitch
I feel special in the STARMADA ,I got this 3/16" alum diamond plate from a friend,I spose this will work on outside of transom
dozerII
to cover all the holes.a full coat of 5200 and clamp her up.
Welcome to the Starmada Kitch, should be an interesting build:couch2::popcorn: I myself wouldn't use the diamond plate for the transom pad the diamonds will leave a gapmaking it vey hard to seal the mounting holes for the O/B.
Kitch
dozerll, your KILLING me! I really love the look of it,but YOU ARE SO RIGHT.
Kitch
Might just mill it flat where the ob. contacts it.
Watermann
:welcome: aboard and to the Starmada Kitch, nice Holi-SS-iner project :lol:
Kitch
Thanks WATERMANN. I feel like Im a smarter boat builder/resto man just being a Member on STARMADA.LOL
Candutch
Welcome Kitch...looking forward to seeing this one, centre console was my first plan but decided to keep mine open bow.
I had the same idea with the 3/16 diamond plate I have. Glad dozer chimed in, I may have to re-think that approach.
Grandad
Read the fine print on your Starmada membership card. It includes the words obsessive and fanatical. - Grandad
jbcurt00
Oops, you forgot the pix codicil. Else the 'crew' will gather w their torches:
Kitch
You guys are GREAT, My cards fine print says STOP NOW OR YOU WILL BE BROKE! But when its in your blood, it is what it is.
Kitch
My grandson/Helper waiting for a RIDE on the quad. thumbnail_20151128_160044.jpg
