1974 19' Starcraft Holiday outboard leak repairs - project
Mark_VTfisherman
Of course one of the quintessential builds for quality and thoroughness is grandad's http://forums.iboats.com/forum/boat...arcraft-holiday-reno-and-hull-repair?t=517895 and I've read that for inspiration, among others.
I'm in the midst of bringing my Holiday back into service. Currently gutted. The hull apparently had a very bad event with the previous owner, and the damage appears like it broke free of its mooring and got pounded ashore, while other 'symptoms' indicate that it may have travelled down the road after unloading itself from the (cox roller bunk) trailer. Like the bow keel aft end that has been flattened off-angle to the port side. Or maybe both!?
I'm having an issue with weeping through the bow keel rivets. They are tight, and have been 'reset' along with replacing about 90 rivets along the hull length. However, it appears that some at the bow keel were either mis-installed from the factory, or an attempted repair from said prior damage was done poorly. However, the factory goopygump in this area appeared undisturbed so... no visible cracks, but some rivets are off-centered in their respective holes. I've poured water in this area, and the 'leak' is minimal as it took most of the day to weep-off a cup of water. (lowered the tongue jack just so to insure water would only be in the 'test' area)
I'm thinking of replacing a few of these with fresh rivets set wet in 5200. I don't want to try to gluvit approach as I view that as temporary - other ares on the boat have this or another product like it applied from the inside and it had failed in every place. (The Starcraft factory goopygump is much tougher and quite was difficult to remove in the bow.) Interestingly, the initial pour-in-water test of this area had water running right out. Now it's a very very minimal weep, so I'm heading in the right direction anyway!
However, because the metal was damaged here, another approach I thought might have merit is using 1/4-28 stainless panhead bolts well-saturated with polyurethane adhesive(5200). This would let me draw the parts down whereas with a couple other re-rivet locations the rivet was not able to sufficiently draw the latitudinal ribs/frames together along the keel thereby leaving me questioning the long term effectiveness of the repairs there. (The hull is sandwiched between the inner frames and keel extrusion as some may already know). I have found no visible stress cracks in the hull, frames, or bowkeel extrusion at the area of concern. After tightening the stainless bolts and nylok nuts, I thought I would scuff the area, acetone wipe it, blow it dry, and use a putty knife to smear-seal the entire riveted area with 5200 to replace the (removed) Starcraft goopygump. The other advantages to 1/4" bolts is that the newly-drilled hole will let me examine for hidden cracks in hull metal, AND the 1/4" hole will swallow the aforementioned space that's around a couple of the (probably factory) rivets.
What are the Starcraft gurus opinions on this approach?
bob johnson
I would suggest as a START is to drill and ream all suspect rivets open to 1/4" and rebuck with a solid 1/4" rivet that's coated with a light coat of 5200...
this way you mate the holes that are not "looking" at each other and you have a clean ROUND hole for each filled perfectly with a new rivet!
beyond that it is possible you crack the skin under the keel.. glove it might help as an insurance.. but its not a guarantee, because you don't know if it is cracked or split open......
id re rivet all suspect rivets and fill the boat with water and check for where the drips materialize first....then plan your next move from there
bob
Mark_VTfisherman
Thanks for the input. That's pretty much what I was thinking. Wouldn't mind thought son using bolts in a few places though. I can't see a negative to it
As far as hidden cracks: I noticed when I plated the port side chine that while there were multiple stress cracks clearly visible on the outside and inside, I also found some cracks /not/ visible. When I examined the drilled out rivet holes, I could see where cracks had started in a few places that hadn't spread beyond the rivet heads - yet. I'm expecting when I drill the keel rivets I'll find similar evidence so I can compensate for that if necessary. At the least this would explain the weeping at the keel; I hate fixing something "blind." At worst (I hope not!) I can remove the keel, examine the holes, and reinstall.
I've purchased some 1/4" stainless oval head philips bolts, stainless nylok nuts, and washers. If the latitudinal frames 'spring' at all leading me to question if a rivet will adequately pein tight I can use these to draw them down to where other holes can be riveted. I have a countersink to prep the keel where they'll pass up through the hull, and either a 1/4" hole, or less desirably, 5/16", should still allow enough 5200 to seal the holes. I plan to install every rivet 'wet' with 5200 whether it looks like it needs it or not anyway- I'm not a factory and a little bit of time to do this isn't a big deal.
I look at grandad's build as inspiring. Some friends have questioned whether 'all this work' is worth it. Well, the boat came to me essentially free, and a supposedly 100% boat of this vintage running with an outboard often sells around here $3500-$6500 range... And that might want some of the same work from what I've seen. I can do an awful lot of repairs and be back in the water for FAR less than that! I have made my own rivet driver from a broken impact hammer chisel, use a heavy block of steel I prepped for a sheet metal dollie I needed on a jeep once, and at this point have purchased under $40 in rivets, hardware, and a caulking tube of 5200. My time, though not "free," doesn't cost me anything. Rivets are cheap and adequate for the job.
So glad to be finally working on it though- I've had this thing wanting to do it for years!
Watermann
Yeah the keel area is one of the most abused area on these boats by impacts and can be the toughest to repair with there being 3 sections joined.
I've not seen stress cracks before in keel rivets, just impact damage. If it were me I wouldn't bore out any rivet holes to 1/4", I would use the same size SS machine bolts for the current 3/16" rivet holes. I think that would be a size 10.
Gluvit epoxy is our rebuilders version of the SC seam smeg, it's not a fix it's insurance. If there's a small breach in the seam sealer the gluvit will find it and fill it. 5200 is great stuff between 2 open surfaces that are to be put together but it has it's limitations, being a seam sealer is not the right use.
Solid rivet tools are pretty simple alright, the brazier head rivet set needs to fit well.
